Frank.B.Smith
- Glen Burnie, MD.
Greetings again,
My contractor was out today to have me sign the contract for the 19 additional solar panels for my Garage. He mentioned that normally he would install an external disconnect on the outside of the garage. He is going to check with the inspector to see if we can do without it.
I will need to do some more research, but I thought the external disconnect was a Utility requirement and NOT a NFPA requirement. The local Utility, BGE, only requires one external disconnect at the Utility entrance to my house. The house and garage are on different streets so the wire leaves from the rear of the house and enters the rear of the garage. The disconnect would most logically be on the rear of the garage and this location makes it unlikely to be seen by the responding fire crews since they would approach from the front of the garage. If the disconnect was located on the front of the garage I fear the local hoodlums (children) would constantly turn it off for fun.
So Is there even a requirement for an external disconnect at each building that has solar. If so which Article is this specified in? Since the detached garage is not also a residence I do not believe an external disconnect is required for fire code. Fire crews seldom risk their lives to save cars in a garage.
Frank
Frank
