That does seem to be the case, but that's what we're stuck with. I don't have any old code books from the 70's, but I'm wondering something. Do you suppose that the redundant ground requirement pre dates the GFCI technology? and perhaps at the time the redundant ground requirement was put in the code it was the best method available at the time to assure overcurrent device operation on a ground fault? and perhaps it should be looked at now to give the GFCI option?Originally posted by jimwalker:
Would it not be safer to have a gfci than a redundant ground ?Seems we spend more and get less
We agree.Originally posted by iwire:
I believe the approx. 5 ma a typical GFCI lets through could be far more dangerous to a patient then to an 'average' person.
Do not forget that the GFCI does not prevent a shock, it only shortens the duration.
Proper grounding and bonding should prevent a shock.
