Bjenks
- East Coast of FL
In Florida engineers are now required to sign and seal government designs. In this case a county lift station drawing has been given to me to not only design the one-line and grounding but to actually sign their standard design. My dilemma is that they show the conduit coming from the grinders out of the ground into a stainless steel junction box then to the seal-offs and then into the control panel.
My standard design is to put the seal-offs before any electrical connections including a junction box. My thought is that I am trying to eliminate any arcing going into a methane gas chamber. If there is ignition then I will supply a path for the explosion and gasses away from any other sources of arcing. I also don't want to use the junction box as part of a seal off system.
However, I noticed that many government systems say the seal-offs must be between the junction box and the control panel. This doesn't seem to make sense to me unless someone can explain why. Also I normally don't allow any type of PVC between the grinder and the seal-off because of explosion issues. I require coated galvanized steel for corrosion and explosion protection, is this off and if so your reasons.
Thanks
Thanks
