PAUL M.
- LAS VEGAS, NV
I was wondering if ayone could give me a ballpark number on some wire. I have Horn/Strobe circuit w/speakers. Also need price on #14 pr for addressable devices.
ADI is selling 14/2 FPL 1M jacketed for $150.00. Shielded will be $$$$$
For what it's worth, I wouldn't get anything other than FPLP unless you have a LOT of non-plenum wire to install. The price difference doesn't justify the grief trying to separate the standard, riser, and plenum installation portions of a job and making sure the appropriate wire goes in each portion. As a former boss of mine once said, "Wire is cheap, labor is expensive". If you have to pull out a run because you put in the wrong type, you've probably sucked up the cost savings for wire on that job and the next five!
GAR,
I agree, and know from personal experience, the wrong type of cable can be a PITA. Having said that, I do a lot of commercial fire and never find plenum where riser/nonplenum will do. Why, well in my opinion the $40/box more is better suited in my pocket. Also, I always check to make sure what is going in, as I will only make that mistake once.
But, I did find mid lakes cable FPLP, on clearance (67$/1M ft.!!). So all I have for repair/service work is that.
For a delta of $40/box, 2.5 boxes is about our hourly charge. Depending on installation conditions and the number of devices, you could easily spend 8 hours replacing 1,000 feet of FPL with FPLP in a drop ceiling "for other environmental air". Now if I had 20,000 of riser to do, that's a different story.
Our price from ADI for 14-2 unshielded is the same as yours. We don't have 14-2 shielded in our inventory system, but 16-2 shielded/unshielded is $120 vs $108; not that big a deal.
