joebell
- New Hampshire
I am working in a building where the PIV keeps going into "trouble". I am not certain as to the trouble ie ground fault, open. The In house electrician thinks that replacing the wiring from the valve to the module in the building will solve the problem. Outside the building there are 2 PIVs being wired from the same junction box. When I opened the box I noticed that both valves were wired in series and connected to the same module. The building has had a panel upgrade from a conventional system to an addressable system. It is my opinion that the 2 valves should be monitereed seperatly. Is there any article in NFPA 72 that I can reference to find this out.
Joe
Joe
