Krusscher
- Washington State
- Electrician
Anyone have a good solution for going from a F64T12 HO to LED? I can find some lamps but they are pretty expensive, like $50 each.
I am trying to put something in that will last longer as these are not easy to get to . They are for back lighting a clock tower. Ideally I would like to get rid of the ballast as well,Replace the lights.
Why not just get a Ballast bypass bulb. its about $60 bucks a bulb.
this is the way I am going. Seemed crazy expensive but PUD rebates are pretty much going to cover the cost.Why not just get a Ballast bypass bulb. its about $60 bucks a bulb. do away with ballast.
Isn't that the point of LED tube replacements? I honestly think they do just as good as far as lumens/color go but they last longer, use less energy and don't lose lumens as fast as fluorescents. I would 100% replace the fixture if it made sense to do so but that also takes more time and cost more. These aren't the LED's of the early 2000's we are dealing with any more. The technology has come a long ways and they hold up way longer then they used to.Again, you can probably buy a new LED luminaire that will provide a much higher quality lighting solution and much longer life for about the same cost as the replacement lamps. Tubular LED replacement lamps underperform their fluorescent equivalents in everything except energy use and life. Get a luminaire that is actually designed for LEDs and for your application. Any LED replacement lamp makes huge compromises to fit the LEDs, heat sinks, drivers, optics, etc. into a fluorescent, incandescent, or HID form factor.
Save yourself and the owner the disappointment and headache of a system that doesn't meet expectations. Replace the luminaires with LED luminaires.
I would think the major part of your time would be dragging tools and materials up into the tower, and the minor part would be the time working on the electrical. Or possibly 50/50Isn't that the point of LED tube replacements? I honestly think they do just as good as far as lumens/color go but they last longer, use less energy and don't lose lumens as fast as fluorescents. I would 100% replace the fixture if it made sense to do so but that also takes more time and cost more. These aren't the LED's of the early 2000's we are dealing with any more. The technology has come a long ways and they hold up way longer then they used to.
Either way this is basically sign lighting I am dealing with so there really isn't any replacing a fixture.
It's 3 sides 8 tubes each and I am going with ballast bypass. Fortunately it is attached to a building and the entrance to the tower is roof level. But getting to the lamps is kind of a bear wince there are 2 panels that need to be taken off on each side with like 20 screws each and its going to be a little awkward to get in there and re wire it. The good thing is I am employed by the college so time isn't a huge factor as I will probably be called off multiple times while working on this.I would think the major part of your time would be dragging tools and materials up into the tower, and the minor part would be the time working on the electrical. Or possibly 50/50
And I would think $50 per tube is reasonable if you're looking for an easy swap for ballast-driven (or easy next time if ballast by-pass)
What are you looking at....clock on 4 sides, with 4 tubes per clock?
I don't know that I would agree with that. All of the expensive and environmentally challenging bits are in the tubular LED replacement lamps as well. What are you saving by keeping the housing? A little bit of steel and some aluminum? A good quality LED luminaire should last a decade or more. How may times will you have to relamp in that time period? Heat causes LEDs to fail, and you cannot manage the heat as well in a tubular LED form factor as you can in a luminaire built for LEDs. The driver is smaller, the heat sinks are smaller, and all the components are built to fit into a tube instead of maximizing performance and life.I would not install a new led fixture. Tubs are nice for customers since they can change the bulb, these new led that you throw away are the opposite of green/energy savors and terrible for customers
