FA Runs
mstrlucky74
NJ
Looking for some insight here. Have hundreds of these rooms like this and looking for others insight. We can run conduit in slab. Would you run conduit in the slab and stub up or down into and out of each device as shown inthe red lines or would you run flex in the furred out wall show by the blueline then vertical where this an accessible ceiling. There are no ceilings in the rooms just the foyer portions hence not being able to run wiring exposed or in conduit exposed. Thanks.
If you're saying there is no chance of running overhead, then in the slab is the only choice. I'm not even sure what the question is.
Why isn't horizontal in the wall an option the go vertical where there is a drop clg....this scenario is shown by blue line.
