stickboy1375
- Litchfield, CT
Is it a fact that screwing in a PAR lamp, or any lamp for that matter with the switch on causes premature failure or certain death of the lamp? Or more of a safety concern?
Isn't this inevitable no matter how the lamp is installed?stickboy1375 said:certain death of the lamp?
480sparky said:If at all possible, I install (edison-base style) bulbs.....er, sorry.... lamps while the power is on.
If this is wrong, I guess I've been doing it wrong for years.
chris kennedy said:Isn't this inevitable no matter how the lamp is installed?
FWIW, I prefer to install lamps with power off.
hillbilly1 said:I have a habit of doing it also, but not to get too far off the original post, We had to go out to a big box store parking lot where the parking lot lighting maintaince contractor had installed a lamp with the power on, and the lamp shattered connecting him to the live electrode inside electrocuting him. The fire department would not get him down until we verified that he was no longer connected. Sad accident, I think the kid was around 22 or 23.
pfalcon said:Last I heard but cannot confirm the veracity thereof:
With the light on during installation you can flicker the bulb when it first makes contact - thereby shortening the bulb life since cycling shortens the bulb life.
With the light on during installation - you get blinded.
If you touch the bulb with your bare hand you leave oily hot spots that shorten the life span. The heat when it turns on may cause additional sweat to shorten the life span.
Jraef said:One or two extra "flickers" is not going to make a noticeable difference in bulb life. But the point about being blinded is valid, especially if you are on a ladder. Oil on the hand transferring to the bulb is a factor only in quartz lamps.
The biggest deal is the "bad lamp detector" issue mentioned above. If the lamp is defective right out of the box, as evidenced by the horror story above, hot installation is a really bad way of discovering that. When I worked for a distributor, lamp mfrs had an allowance of 15% usage reimbursement to cover defective lamps. So in other words, they ACKNOWLEDGED up front that they expected 15% of them to be defective and distributors could replace them, no questions asked. Of those, not all of them are going to pop in your hands when energized, but Murphy's Law prevails and when it happens to you, it will be at the worst possible moment!
Because the low-voltage bulb has a short, thick filament, while the high-voltage bulb has a long, thin one. Ohm's Law. :smile:whillis said:If they could make one bulb last, why not the other?
