bjfowler
- Lexington/Alabama/35648
- Instrumentation and controls technician
I am seeking some advice on an issue I have recently discovered on my 3 year old fiberglass pool. I noticed a small electrical tingle getting out of the pool a couple of days ago and troubleshooting revealed that my equipotential bond is broken in possibly 3 different places as well as there is a 5 volt Neutral to Earth problem coming from my utilities. The Utility company verified there is a problem and just replaced the entire cables from the transformer to my house since there was a splice when they replaced the pole a few years ago. This did not correct the problem and they are continuing to troubleshoot in the area for a bad neutral connection. I'm not confident they will resolve that problem, but regardless I know I have a bonding problem now that needs to be fixed. In certain areas of the pool, I can measure up to 3 volts AC between the water and the concrete decking. When the pool was installed, I used a copper mesh grid encircling the entire pool tied back to the pool pump and heater bonding terminals 30 feet away. I do not have any handrails or other metallic components anywhere within 30 feet of the pool. The mesh is connected by 8 awg on one end of the pool, opposite the skimmer. The skimmer has a water bond that is connected to the mesh on the other end of the pool. I verified that I have no connection between the skimmer bond and the pump bond terminal anymore. So now the water is not bonded. The concrete (which is fiber reinforced and has no rebar) has cracked at three different places, one on side of the pool a 2 on the other in the expansion joints and separated approximately 1/16 of an inch, where I can measure a voltage drop up to the 3 volts between 2 of the separated slabs. It appears that the shift in the concrete broke the grid. I'm assuming that the only way to fix this is to cut up a section of the concrete at the breaks and reconnect the grid. I'm afraid that it may happen again though or break in a different spot. The grid was placed on top of 5 inches of gravel base which has 4 inches concrete poured on top of it. Was this incorrect? If anyone has suggestions on the best way to proceed, I'm all ears.
