RICHRICH36
- Florida
Hello. I ran a circuit to a mini split condenser. I believe I am being hung out to dry because I am not in this "good ol boy network"
I failed for the following reasons.
No disconnect at the air handler. Keep in mind this is a mini split that obtains its power from the condenser (which has disconnecting means). I asked the inspector sarcastically, should I install a 60 amp pull out at each of these air handlers (there is 3) in the bedrooms and he said that would work perfectly fine.
I also failed my inspection and was written up for the AC contractors running their interconnect between the condenser and AHU's. The inspector stated that because the AHU is line voltage that it has to be done by the EC.
I attached a picture of the laundry list of the articles cited.
My question, is it out of the AC contractors scope to run the connection between the units and who has ever had to put a disconnect on a AHU of a mini split system that obtains its power from the condensor.
