- Lockport, IL
- Semi-Retired Electrical Engineer
Consider a site with 50+ small buildings. Each is about 50' x 100'. Typical distance between buildings is around 200 feet. Each has a ground ring bonded to its service panel and to a lightning protection system. The ground ring surrounding each building is bonded to the ground ring of at least one other building, so that all rings are bonded to each other.
Questions:
Questions:
- Is it possible to conduct a standard 3-point fall of potential test at each building, and obtain a reliable result, despite the presence of the ground rings associated with the other buildings?
- Are the buildings too close to one another to allow placement of the probes as far from the building under test as the test process requires, or would the probes have to be so far from the building under test that they end up inside the ground ring of another building?
