Frank...are you talking air handlers in the attic?
I'm not sure what a Fan Coil Unit is:-?
It's a split ac unit, compressor/condenser outside piped to a fan/coil inside the building,
all the duct work supply/return is fitted to the FCU (fan coil unit). Some FCU's are fitted
with Electric heating coils. Normally the ac compressor is on it's own circuit and the FCU
is on it's own circuit. The FCU is located above the ceiling space and a disconnect is
required, but space is limited and many times 110.26 is next to impossible.
