W white stallion Member Location El Paso, Texas Sep 28, 2016 #1 What is the operational clearance for a motor disconnect switch on a fan coil unit mounted above a ceiling? Is it 3 ft.?
iwire Moderator Staff member Location Massachusetts Sep 28, 2016 #2 Its really one of those times where the code does not address this issue. There is no way to mount a disconnect switch above a suspended ceiling and comply with all the rules in 110.26.
jumper Senior Member Location 3 Hr 2 Min from Winged Horses Sep 28, 2016 #3 white stallion said: What is the operational clearance for a motor disconnect switch on a fan coil unit mounted above a ceiling? Is it 3 ft.? Click to expand... Code wise or in real life? Code wise would be 3' or 3'6", but in reality 1' most of the time, 2' if you are lucky.
