elecold
On the side of the fan coil unit is a small switch is that adequate for a disconnecting means? It comes existing from the factory
If I elected to install a disconnect would it have to be fused
On on the nameplate sticker.. it says motor 277 volt 1/3 horsepower. quantity 2. full load amperage 2.6 A
Circuit MCA 5.8 amp
Circuit MOP 15 amp
I really appreciate any guidance that you can give me
Circuit MCA 5.8 amp
Circuit MOP 15 amp
