A. Magic
B. Multi winding motor.
C. A really cheap Chinese speed control.
While we're on cheap fans, anyone know why the first fan speed from off is always HIGH? I'd think this would be harder on the motors than going to low, then medium, then high, but the sheer number of fans I've seen wired Off-High-Med-Low would indicate otherwise.
You want to be sure that there is enough torque to break loose gunked up bearings and static friction. Once the blades are moving you can reduce the power.
+2You want to be sure that there is enough torque to break loose gunked up bearings and static friction. Once the blades are moving you can reduce the power.
