welectrical
- NY/CT/MA
- Engineer
Not sure if there's a better sub to post this in, but I am designing a job where a faraday cage is being installed for brain scanning / reading. However, the room needs power for lighting, equipment use, etc. It also needs data connections within.
I know MRI rooms are common faraday cage applications, how do you bring power/data into them without destroying the cage's properties?
Does one use non-conducting conduits within the room and outside of the room then use a shielded cable that is grounded to the room's cage?
