Well, the three farrms I had dealings with were all in the eighties so...
but all were pretty similar. had a meter up near the road, a line ran up the drive across several poles toward the house, and there you had a disconnect that allowed the whole farm to be disconnected... that went back up the pole with a wire from the pole to the house, which entered a panel with main breaker etc... then you had different lines from the pole strung out to the different buildings that got power, each of them also having what was a main panel and breaker... not sure how legal such a set up was or is, but at all of them the panels were usually the screw in fuses, except for old man Peckinpaughs Dairy barn, with the fancy milk machines... that one had a new breaker panel on it. Even the crew quarters or bunk house as he called it had a panel just inside the door.
Frank was the one who taught me wiring, well, what little I know, and I can tell you, he checked every one of those buildings before he reconnected the wires to them. Remember him running a trench between two of the buildings and stringing in wire to the ground rods because he said the buildings needed connected... he said that was something he learned working for Dupont...
