jetlag
- Eatonton, Georgia
I cant find it now , but wasn't there an exception about NM has to fastened within 12 " of a box clamp when the cables enter a panel box through drilled plates not over 4.5 ft above or below the panel ? In other words if all the cables cant be fastened to a stud do you have to put a cross piece between the studs 12" from panel to fasten the NM ? Also I got flagged for not having a staple within 8" of where a cable comes through a plate and is stapled to a stud . I allways put a staple in that general area but never worried about the exact 8" . I cant find that in code either . If that is true will I also have to put a cross piece 8" from the plates where the panel is ? I usually put the cross piece 12'' from panel but I just thought I remembered an exception.
