wewirepgh
- pgh steelers
What an easy way to fasten a piece plywood or osb to sandstone (uneven surface) foundations?
Brian Johns said:I like to use the dowel rod method of drilling a 3/4 hole about 4" deep, cut a piece of 3/4 dowel rod to 4" , then i coat it with construction adhesive meant for cement or stone and insert the dowel, i pilot drill the centers for the first 1" before inserting them,
mdshunk said:If this is indoors, in a basement, I don't even try to fasten to rubble and stone foundations. I just "hang" a couple 2x4's from the joists above and put the plywood on that. If I'm doing big equipment, those hung 2x4's will be extended nearly to the floor, a pressure treated bottom plate attached, and it will be anchored to the floor. Completely takes the stone wall out of the equation.
Brian Johns said:I'm not mounting the electrical equipment to the rock, sandstone, concrete, plaster, etc....I'm mountng the plywood backplate. The electrical equipment is then mounted to the plywood with wood screws.
iwire said:That describes what I had to do in my own basement, works much better then messing with the stone.
Brian Johns said:I totally agree, well kinda, maybe just move the whole mess up and outside.
peter d said:What, are you from the west coast or something?
