Alwayslearningelec
- NJ
- Estimator
A 1P 208v fan coil unit would required NO neutral? Just 2 hot legs? Also if running in EMT can use conduit as ground?
Try not to be so wordy, next time.Yes, yes, and yes.
Most of the time I would say it is not the customer that puts the green wire it is the engineer who draws the plans. The customer probably doesn't care about or want the green wire.Customer may require a ground pulled though in their specs. We don’t have many customers that don’t have that in their specifications.
Try not to be so wordy, next time.![]()
