I would like your input regarding this situation, I didn't have enough time to evaluate better. An electrical furnace was replaced for a gas furnace some time ago. Please see photos. The main service panel is a Federal Pacific one. The installer pigtailed, at the furnace, with 12 AWG (the right wage for this furnace) to the existing large gauge wiring that were use for the electrical furnace, and leaving the same large wiring all the way to the service panel (about 30/40') and there the ungrounded (the red one) is connected directly to the 20 amps breaker (I assume the installer removed some strands to accommodated this breaker). The installer left the same bare grounding as original installed and pigtailed the large neutral with the 12 AWG.
The property is for sale and I was called to replace all receptacles and switches for Decora and installation of GFCI were needed. The owner does not want to replace the Federal Pacific Panel, here in WA is not mandatory as in another communities, and really this panel "looks clean" the breakers are working, at this moment, normally. In my opinion this furnace/wiring installation looks ugly but really I don't see any hazards as the 12s are pigtailed with this heavy conductors, unless some strands were removed on the ungrounded but it can be pigtailed as well and attach the 12 to the breaker. "If it were for me I replace the entire panel"
I appreciate your inputs ....
