Re: Federal Pacific-Problem with breakers?
I was involved in the recall FPE did in the early 80's and while I no longer have the documentation regarding the recall; as I remember it, the problem was (AT THAT TIME) with 480/600-volt circuit breakers, The AIC ratings were not up to the task. We replaced the FPE circuit breakers with GE circuit breakers, the GE circuit breakers were furnished by FPE.
We did nothing with residential circuit breakers and as I remember it, no residential snap in circuit breakers was listed as being a recall item. That does not mean there was not a problem with these circuit breakers. But by no means is this an endorsement of their snap in type circuit breaker, the design was lousy from the start the stab lost tension at the bus connection. I have seen this many times with circuit breakers carrying full load capacity.
As far a FPE Canada goes, this was a company that made transformers and ground fault controls, I do no believe they were in the circuit breaker business.
We always said FPE = Fix Prior T0 Energizing
Unfortunately residential market is the low end (Usually) FPE, Zinsco, and some others I will not mention, myself when I wired my house I used Square D QO's.
We have some properties in this area that have a double threat wired in the mid 70's all aluminum wiring and FPE or Zinsco panels.
[ April 15, 2005, 04:45 PM: Message edited by: brian john ]
