Zapdog
- Malibu, California
Hello, I'm bidding a residential job where I'll be upgrading an existing 100 amp service to 200 amps to accommodate a new air conditioning system . The main service sits on the side of the detached garage in the rear of the property ( the panel is an "all in one"). The house is fed by an existing 90 amp underground circuit from the garage to a 30 space sub panel. The 5 ton condenser will sit in the back yard near the rear of the deck off the family room. And I plan to feed it from the new 200 amp main service panel on the garage, but I'm wondering now if there is anything in the code that says I cannot feed equipment servicing one building (house) from another building (garage). And I'm perplexed.... might be losing sleep on this one. Personally, I don't see a problem with this, being that the condenser is essentially electrically isolated from the house except for the 2 conductor control wire from the FAU.
I'll probably try to call the AHJ in the morning, but until then I was hoping someone could share their thoughts on this one.
Thanks, Mike
Thanks, Mike
