jamesguy10
- Amsterdam NY
If i have a 200 amp main breaker panel, with feed through lugs at the bottom feeding another panel, can a SE feed the second panel with seperate #2 grounds run from both panels to the ground rods? The feed through lugs are protected by the main breaker, so there is no grouping disconnect problems.
