AKB
Just wondering
- Hillsdale, NJ
- Contractor
Hi, I have a 400 A MCB 3-P main panel with feed through lugs. I used 4/0 Cu wire to 200 A fused disconnect.
Inspector says, you can't use 4/0, it has to be 500 MCM or larger.
Am I not protecting 4/0 with 200 A fuses? Any relevant code section in NEC says I need to use full size from feed through to 200 A fused disconnect?
Thank you,
Thank you,
