Re: Feed-thru Lugs
Terms like sub-feed and thru-feed are not universally defined in our industry.
I have always used these definitions (wish I could post drawings):
In a main lug panel;
Thru-feed means the second panel is fed off of the bussing of the first panel - the first panel needs to include the load of the second panel.
Sub-feed means the second panel is fed off of the lugs of the first panel - the first panel does not need to include the load of the second panel however the feeder does.
In a main breaker panel;
Thru-feed means the second panel is fed off of the bussing of the first panel after the branch breakers - the first panel needs to include the load of the second panel.
Sub-feed means the second panel is fed off of the bussing of the first panel after the main but before the branchs - the first panel needs to include the load of the second panel
