Ive got a question on feed thru lugs in a panel. Lets say you have a 200 amp panel with feed thru lugs on he bottom. Does this mean that the bus in the panel has a higher rating than 200 amps. The reason I ask this is because sometimes you will see lugs that were tapped into a buss andthen used as a feed thru. Would the buss be rated for this or not? Thanks
