feed wire for a 30KVA 3ph transformer
KC2LLW
New member
Hello,
Just want to check my wire size. I am feeding a 3Ph 30KVA 480 IN 240 OUT transformer from a 480 buss-way about a 20' run. would i be able to use #4 AWG THHN wire to feed the transformer? the transformer will be running a heat tunnel that's rated at 64amp 240V 3Ph the tunnel has a cord with #2 AWG wire.
Thanks,
Steve
I am closing this thread, in accordance with forum rules. This forum is intended for electricians, electrical contractors, electrical inspectors, electrical engineers, and other members of the electrical industry. If you are not employed in this industry, then we are not permitted to assist you in the performance of electrical installation work. If I have misinterpreted the situation, if for example you are licensed in your jurisdiction to perform electrical work, then please send me a private message to explain the circumstances.
