Having a difficult time with this wording  “The minimum feeder-circuit conductor size, before the application of any adjustment or correction factors, shall have an allowable ampacity not less than the noncontinuous load plus 125 percent of the continuous load.”
Why isn't that phrased to say "after" instead of "before"? If says after then it would read, “The minimum feeder-circuit conductor size, after the application of any adjustment or correction factors, shall have an allowable ampacity not less than the noncontinuous load plus 125 percent of the continuous load.” Doesn’t the ampacity adjustment or correction factors determine the minimum conductor size?
