Feeder Bet. Sections
Alwayslearningelec
NJ
Estimator
So as you can see this is one piece. A few section potentially. They have a feeder tag where they call for conduit and wire but that doesn't seem right to me.
I'd assume this would be either a cable or bus tie. Make sense?? I'll reach out to vendor but wanted others thoughts. Thanks
Not sure what you’re asking. I don’t see anything about conduit or wire in this image.
Apologies, pic did not come out completely. Feeder tag H-102 is for conduit and wire. I've seen this before between sections of gear but believe it's just a cable or bus tie? Conduit/wire really wouldn't make sense. I believe.
It’s cable. Field installed.
ty. So internally obviously? Cable like individual conductors under one jacket or individual wires? Thanks
Not enough information to determine that. It could be internal or external to the gear.
Check the raceway and feeder schedule. Drawings can also be wrong. I’ve seen this once where it said it was a cable, but it ended up being braid/links.
Yes it’s a conduit and wire size . But I’ve seen where they listed that and it ended up being cable tie. Why the heck would they have conduit a cable to an attached section right next to the other section?
I'm stumped. RFI time. :)
