L8TRG8TR
- North Fort Myers,fl
I'm confused.if im pulling a bond with all my runs are bonding bushing or locknuts required ?
Based on NEC only this is not true. Over 250 volts or when encountering concentric/eccentric knockouts often requires additional bonding methods and some equipment is listed to not require additional bonding in those instances. Service raceways are the other case where additional bonding methods may be required.More information is need to help. Are you pulling in EMT? PVC?
If EMT or any other metallic tubing, then yes you are required to have ground bushings, make sure it is continuous as well.
-HDT
