Hello All! This is my first post so please go easy on me. Long time reader of the forums however.
I have a wireway with several taps into fused disconnects feeding 2 chillers and 3 pump motors. It is currently fed from a 208V 3 phase 600A circuit breaker. We are replacing the chillers with slightly larger ones and I need to see if the 600A breaker is large enough or if we need to go to a larger size. Here is my thought process.
I am using the 2017 NEC and going through what it says in 440.110 (C).
Full-Load Current Calculation
Chiller 1 Compressor A - RLA = 48A
Chiller 1 Compressor B - RLA = 48A
Chiller 1 Compressor C - RLA = 122A
Chiller 2 Compressor A - RLA = 48A
Chiller 2 Compressor B - RLA = 48A
Chiller 2 Compressor C - RLA = 122A
Pump 1 - 3 HP (10.6A from 430.250)
Pump 2 - 3 HP (10.6A from 430.250)
Pump 3 - 3 HP (10.6A from 430.250)
Total full load current = 467.8A
Total Full load current * 115% = 537.97A
Locked Rotor Current Calculation
Chiller 1 Compressor A - LRA = 351A
Chiller 1 Compressor B - LRA = 351A
Chiller 1 Compressor C - LRA = 1010A
Chiller 2 Compressor A - LRA = 351A
Chiller 2 Compressor B - LRA = 351A
Chiller 2 Compressor C - LRA = 1010A
Pump 1 - 3 HP (71A from 430.251(B))
Pump 2 - 3 HP (71A from 430.251(B))
Pump 3 - 3 HP (71A from 430.251(B))
Total Locked Rotor Current = 3637A
Now here is where I am having a problem. When I go to look at Table 430.251(B) for the equivalent HP based on the total LRA I see that the table stops at 3207A. which isn't very close to the 3637A that I have calculated. The 3207 LRA is the equivalent of a 200HP motor according to the table. a 200HP motor has 528 FLA according to 430.250.
Does this mean that for any LRA over 3207A we just use a 200HP motor for the rest of the calculation?
Lets say for arguments sake that my total LRA was MUCH higher than 3207A. What do we do then?
Thanks All!
Thanks All!
