For an upcoming transmitter install, I discovered that the 200 amp fused disconnect with 125 A fuses, I intend to use is tapped from a 4 wire 3/0 feeder with #2 wire . There is also a #3 tap from the 3/0 feeder supplying a 100 amp single phase panel fed from phases A and C (high leg delta service). The supply for the 3/0 feeder is tapped directly from an outdoor ATS with 400 amp overcurrent protection and runs about 35 feet through a crawlspace and then a ceiling to the location of the junction box containing the taps to the panel and disconnect.
The neutral and EGC for the 100 amp panel are tied to the 3/0 feeder.
In my mind the 3/0 feeder is a violation of the 240.21 tap rules since it is both greater than 25 feet and supplies other taps. In addition, the neutral and EGC connection is a 250.24(5) violation.
Would the following be a compliant solution:
1) Install a 200 amp fused disconnect within 25 feet of the supply to the 3/0 feeder.
2) Subject to a load calc reduce the 100 amp panel breaker to 70 amps.
3) Break the EGC/neutral connection in the junction box and pull a #4 EGC(EMT is 2 in so it would not be overfilled) or use the EMT as the EGC.
4) Supply the 125 amp OPCD/Disconnect for the transmitter with #1 since the allowances of 240.4(B) are not permitted for tap conductors.
