hhsting
- Glen bunie, md, us
- Junior plan reviewer
I have feeder which is tapped from service equipment trough that has main service disco . The tapped feeder goes into disconnect at bldg #1. The feeder from bldg #1 goes to another building bldg #2 which goes into transformer primary breaker disconnect at bldg #2. The transformer primary is 480V delta so their is no neutral brought from bldg #1 service equipment trough.
Understand 250.32(A) requires grounding electrode system but I have no neutral since transformer primary disconnect is delta at bldg #2.
Questions:
1. Would grounding electrode system at bldg #2 still be required?
2. Since their is no neutral brought their is only one bus equipment grounding bar to which GES would be connected to?
Questions:
