caskscob
New User
- Conroe, TX
- Electronics Technician
I am installing a sub panel in my newly built detached metal structure workshop. I have found conflicting information on the grounding for this. Previously I found multiple sources that indicated that you should run 3 conductors (L,L,N) from the main panel and then separate the ground and neutral bars at the sub panel and install 2 grounding rods at the sub panel minimum 6' apart. That is what I did. Now I am finding information that is saying I need to run a ground also from the main panel. Which is accurate? I ran 210' of cable in a trench from house to workshop already and I hope I don't have to dig that up to add a ground wire.
Thanks in advance.
Thanks in advance.
