68Malibu383
- Raleigh, NC
Hey all,
I'm going to run a 2/0 Al feed from my house to detached garage. I'm using schedule 40 conduit buried 18" below grade. My septic pump tank (takes water from septic tank and pumps to remote septic field a long ways away) is 20" below grade and I'd need to run the electrical conduit over the pump tank. The lid is raised above grade and the electrical will not interfere with access to the tank interior. However, can I run the conduit over the tank or is there a rule against this? The only issue I could see is that if the pump tank needed to be replace, the electrical would need to be cut into.
