have been reading Article 430 of the code and came to the section of Motor feeder short circuit and ground fault protection.
Something has puzzled me in 430.62 (a). What I am not understanding is how this code applies to the number of motors that the feeder will have on it along with specific of 440. 22 (a).
What I am trying to say is; Does the sum of 440.22(a) need to be added to the sum of the largest rating or setting of the branch-circuit shor circuit and groundfault protection device plus the sum of the full load currents?
I am rather confused.
As an example:
Determine the minimum required branch-circuit short-circuit and ground fault protection and the feeder protection for 3-2hp 230v 1ph, 4-3/4hp 230v 1 ph motors; 5-208/230v Pool heater with hermatic compressors and 37 amp load current each. And how about putting 8-300 watt pool transformers with the pool equipment panel along with 35 step lights each with 2amps of operating current each. On a 208v 3ph 4wire feeder.
I am using a real installation for an example. Any help with understand the code requirements of properly sizing the feeders for the panel and protection is greatlyh appreciated.
As an example:
