Welcome...
Might depend on who you are wanting to please, the inspector or the customer :grin:
As k-wired notes... a few variables left unanswered.,
If we assume the RV might actually need the full capacity, and you are able to distribute your loads on a 240/120 feeder so the pump is on the phase with the RV then you are looking at a 50 amp load per phase.
If you want to keep a 3% voltage drop, a #6 should suffice, but with that large a 120v motor I would be leery.
