FEEDER SIZING LESS THAN 100A
gnu_mike
I thought I had read on this forum that sizing feeders for less than 100A demand utilizes the 60 degree C column from table 310-16.
Is this right?
Re: FEEDER SIZING LESS THAN 100A
In reality, I think most terminations are rated for 75 degrees. For example, Square D type NQOD breakers have a note:
10-30 amp breakers are suitable for use with 60 or 75 degree conductors. 35-125 amp breakers are suitable for use with 75 degree conductors.
I assume that means you can use the 75 deg. column if both ends of the wire are landed on NQOD breakers.
STeve
