831
- South Jordan, Utah
Ok...
I've got several sump pumps to feed. I'm going to run a 2/0 to cover voltage drop. If it weren't for the distance, I'd be fine w/ #8. 430.28(3) implies that my tap conductor needs to be not less than the feeder size.
Since the feeder is sized for drop only, should my tap be sized the same?
I am over 25' from the tap point to the disconect @ the motor. A simple sketch:
