jonshoemaker
I have calculated the load on a sub panel and I am wodering if the "high leg" ungrounded feeder wire can be a smaller size than L1 and L3.
The load on L1 is 123 amps, L2 is 53 amps, L3 is 123 amps. This is a 120/240 four wire delta system.
The load calculation program that I used to obtain these values recommended #1/0 THHN Cu for L1 and L3 and
# 6 THHN Cu for L2, neutral, and ground.
Any comments will be greatly appreciated.
