I was wondering if I made a good (maybe not the best) decision to run power to a newly built garage.
Details:
Existing 200 amp service in the house
1/0 3C Cu Running 250+-Ft in NM conduit to the garage.
Underground with 18" Cover.
No other metallic paths.
Is the best choice a 100A breaker in the main box to feed this line?
Or should the line from the meter run to a disconnect and be split to 2 breakers, one for the house and one for the garage?
Is there a code concerning at what point the conduit enters the house? I have yet to find this.
At this point I could go ether way as the feeder wire is the only thing installed in the ground(did not yet punch a hole into the house).
Thanks for your input.
Mike
Details:
Mike
