It's not concrete encased , and again do I size the Fedder for the breaker in the ats or do I size it per the motor
Sent from my SM-G965U using Tapatalk
Is the ATS part of a combination fire pump controller/ATS?
695.4(B) Disconnecting Means and Overcurrent Protection.
(2) Generator Supply. When required to be connected to an emergency generator, fire pumps and
limited service fire pumps shall have overcurrent protection selected in accordance with the following,
except where direct connection is made in accordance with 695.4(A)(3) Exception 1:
(1) Fire Pump. Fire pumps shall be protected by an over current device selected at not less than
150 percent and not more than 300 percent of motor full load current.
Uget an FLC of 211 at 150% i get 316.5 amps next size up is 350 my guess is 400a is a sufficient size OCPD but the conductors I'm having trouble seeing that as compliant 2sets of 2/0 gives me 175 per set for a total of 350 , so do I just down size the breaker or leave it alone
So the two sets of 2/0 are sufficient then
#2/0 copper is rated 145 A (60 deg), so it's 145 x 2 = 290 A, good if your lines are short.
Your OCPD should only be designed to trip only on short-circuit. Referring to 430.251(A) for locked-rotor amps, a 75 HP motor has a LRA of 1200 A.
