Can a Swimming pool panel that has regular breakers, be fed by a 60amp. GFCI breaker at the main panel in a single family dwelling?
It is my contention that the final over current device is where the GFCI protection should be. Upon looking at the definition of Ground-Fault Circuit Interrupters in 680.5, I'm wondering if a feeder GFCI would be code compliant, or if the breakers for the pool heater, pool pump, and pool cover would have to be GFCI type breakers?
I would appreciate some other professional opinions.
Thank You,
Bowhunter
Thank You,
Bowhunter
