zcanyonboltz
- denver
My buddy is doing a service change on a house and then wiring an addition does anyone see a problem with feeding a 150 amp panel from a two hundred amp panel? I don't know the load calculation on the addition but it will have a welder, dryer and an RV receptacle and a well pump and then some general lighting and receptacle circuits. I recommended a 125 amp panel at the addition fed with 1/0 SER and then run 2/0 to it in case a 150 is necessary. I can't think of any code violations or problems with feeding a 150 amp panel from a two hundred amp panel but this isn't very common just wanted some opinions thank you.
