Hi everyone,
I have an existing 200 meter mounted on a customer owned pole sitting in between two structures, a barn, and a house. The pole is roughly 70 feet from each building. Originally there were two over head drops coming off the same meter going to each building. The house was recently updated and the new service is going to be underground from the customer owned pole. We have to upgrade the meter pan to a meter/disconnect combo and my question is does anyone make a 200 amp meter disconnect combo that can be mounted on a pole that has sub feed lugs ? In other words is there a meter pan with 200 amp disconnect that allows me to run back up the pole and feed the over head to the barn and also come out the bottom to feed the underground to the house ? If not is there a recommendation on how to do it without adding a pad or pedestals ? I would like to not have to redo the overhead going to the barn....
