- Tennessee NEC:2017
- Semi-Retired Electrician
Lets say you have a main panel board and you put a sub panel beside it. The subpanel will feed new loads. In the main panel, there is a load/circuit that is being moved. Do you see a problem with, instead of piping out of the main with the conductors, you feed them into the subpanel and pipe them out with the new feeds? They would just go straight through and not land on a breaker. It would make for a faster/cleaner installation. I can't find anything prohibiting it.
