fisherelectric
- Northern Va
I have a customer who needs a new pool house and a
garage wired on his property. He had a brand new 30/40 circ 200 amp service permanently installed on a pole in his yard for this purpose. The poolhouse is going to have approx. 86 amp load max, with kitchenette, dishwasher, refrig, HVAC,water heater, etc. This pool house is approx. 350 feet from the pole, which I have figured will require 2/0 al to maintain voltage drop within 3% to 5%. I'm going to suggest changing his brand new (unused) 30/40 panel to a Siemans WO816B1200CT. This is a 200amp MB panel with feed thru lugs and 16 spaces. Then feed a 200 amp mainbreaker panel in the poolhouse (as a sub-panel) using 4/0 al off the feedthru lugs. The garage will be fed seperately. This will give him room to expand at the pool house, solve the voltage drop problem, and eliminate dealing with a breaker for the poolhouse. Sound right to you?
Can you run a seperate EGC with URD?
Not sure what that feedthru panel costs yet.
