Pok3r
- Yuma Az united States
Would Spring Retractable Grounding Reel
Be legal in this case?
It's not necessary to dig up the road.
https://www.borit.com/
With my luck I'd hit a piece of lv, irrigation, or telephony cable in that 20'. But neat device.
If it's adequately supported and adequately protected from physical damage & lightning strikes, I don't see why not, even if "overhead ground wire" is a bit of a non sequitur.Hypothetically, could you go aerial with a bonding jumper here? ...
Push a sleeve through with water or air via compressor. Use a 2" schd80 sleeve attach a 3/4" cpvc to the hose and easily advance the sleeve through. I've done it for distances a bit further than 24'.![]()
