- New Jersey
- Journeyman Electrician (retired)
I have a new deck where she wants string lights hung across the deck. There will be a 1/8" stainless steel messenger cable with the lights attached to it. So here's the question. These light kits (from Amazon) are dimmable and have a plug on the end, designed to plug into an outdoor receptacle. Now if these lights are on a dimmer how would you wire them? Receptacles requires GFCI protection so a receptacle at the end of the circuit won't work being controlled by a dimmer. I'm thinking the only code compliant way to wire these is cut off the plug and to hardwire them. Thoughts?
